6 members (MRMEROTH11, cmayna, David Bush, Hanks custodian, walter74, 1 invisible), 53 guests, and 3 robots.
Topics128,056
Posts1,055,800
#1150050 02/14/2016 4:57 AM
Is primer color a consideration? If I am going to paint dark green would a dark or black primer be better than a light gray primer? Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
homer52 #1150107 02/14/2016 3:36 PM
You will....get chips, they are unavoidable, a light white/gray
primer will stand out like a sore thumb.
Typically a light color primer will work better under a light
color and vise versa for the dark. The less contrast between
the two the less you will notice it.
Also in some cases your choice of the primer base can lighten or
darken your top coat unless you are laying down multiple heavy
coats of finish.
Here's an example of the prep for a Mariner Blue paint finish.
Grills get a lot of chips if the vehicle is driven:
Grill-bars-in-prime
On the hood and fenders I made the mistake of using
DP50 light gray and I'm paying the price.
When I was involved with aerobatics, it was just good common
practice to paint your fuselage a light color such as light
gray. The contrast of a dark crack on the light background
showed up where it would go undetected with a dark background.
Thought you we're all finished with your Art Daco Dave?
dg
homer52 #1150152 02/14/2016 6:39 PM
The 41 is about done. I am building a bit of a hotrod, 46 on an s10 frame it is coming along nicely. Now I suppose you want to see a picture! Dave
Just looked at my photo bucket, there is a picture of me bringing it home, taken at the top of turnigain pass being towed by a blue F €€d.
1941 Chevy
homer52 #1150184 02/14/2016 10:05 PM
What 'cha got in the back ground there Dave, a Super Cub?
Ya got it on skis in the winter??
I've still got a set of plans for a WagAero Cubby that I'd
planned on building after I got the Wag-A-Bond flying. I got
it finished up to the point of cover but never got it done
before I had to accept that flying was not for the blue collar
class. Try as I may, I never could break out of my class structure.
But before that day, I did get about 300 hours in the Pitts
S1D I built before it. Both went within a few months of
each other and I had tears in my eyes as each faded out
of sight down Route 34 on the back of someone else's trailer.
dg
Denny G
Sandwich, IL
homer52 #1150195 02/15/2016 12:15 AM
Supercub on Beaver Floats
Denny, yes on the supercub, not enough snow for skis here. This is how my cub gotback to town before I rebuilt it.
homer52 #1150202 02/15/2016 12:32 AM
homer52,
I cannot get your link to work (and it is so long it messes up my display).
Oh, well.
homer52 #1150295 02/15/2016 2:10 PM
And it did work for me, came home in pieces I see.
Never realized a beaver was that big, always though
they were a bit bigger than a 172 or maybe a 182.
tks
dg
Denny G
Sandwich, IL
homer52 #1150400 02/16/2016 1:48 AM
If your painter knows what he is doing, he will put some of the paint/color in the primer!!
homer52 #1150416 02/16/2016 2:57 AM
I am the painter.
1941 Chevy
