6 members (Wally / Montana, WICruiser, Otto Skorzeny, Gray_Ghost, rfs56trk, 1 invisible), 86 guests, and 0 robots.
Topics128,052
Posts1,055,728
#1150080 02/14/2016 8:13 AM
On these after market tail lights it has a black and green wire which is the tail lights and which is the stop lights ?
If the bulbs are the same it dosent matter
Choose the same position
Example. Lower bulb tail, upper brake/stop
Ok Thxs . That's how I installed just wasn't sure . Both bulbs are the same
If this is the type you have
...pic...
I think you will be disappointed with the results.
Yes those are exactly what i have .. Why well I be disappointed ?
Not very bright
The brake/stop in no brighter than the tail
If I remember correctly one is mounted upside down opposite from the other side.
Exactly what have there is basically two bulbs in the housing which is the tail light then the other for stop light . So how do u fix this problem ?
I bought a set of trailer lights and removed the "innards" and fitted them into the stock housings. So I had running lights, brake lights and turn signals. the trailer light parts were quite a bit heavier than the stock replacements.
Another quality post.
Real Trucks Rattle
Do u have a pic of those
Ex Hall Monitor
Ex Hall Monitor
Read my reply to your other thread on the same subject.
sorry no pics... I bought stock type lights and was not happy with the flimsey inside parts. the trailer lights are typical of those found in any auto parts store.
Real Trucks Rattle
