9 members (Nick in Manitou, Gray_Ghost, Shade Baby, J Lucas, TUTS 59, Bill Hanlon, papas52, 2 invisible),
120
Mod | | | Forums66 Topics128,119 Posts1,056,313 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thought this might come in handy for anyone bullheaded enough to still be running the original 6v system. Made a fuel economy run yesterday in my stock 1950, 3600 and wanted a good reliable speed check. I took the TomTom GPS out of my 2014 Silverado and plugged it into the 6volt lighter socket in my '50 and ran it for 5 hours/150 miles and it worked perfectly. Apparently the voltage regulator in the GPS is able to still operate the device on a lower input voltage. I'm pretty sure the wallwart to charge it on the house voltage, which by the way, has been lost almost from day one, outputs around 5v, that's quite typical for SS devices. So it looks like the 12v input is dropped to a lower voltage when using it with the 12v system and it will run it on a 6v system also.
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | That is logical, glad you tried it. Next someone try a phone charger, I bet they also work on 6V, as the phone and USB devices are also about 5V | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Good idea Grigg. I Picked up a couple of those lighter to USB adapters last month, not knowing that the Silverado and Sweetie Face's '15 Ford already had USB ports. So I will...try one in the '50 and see if it will power up my flip phone.
dg
| | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | So now you're telling me I didn't need to spend the $70 for my 6-12v stepup to run my GPS???? Thanks Denny!!
| | | | | Joined: Apr 2011 Posts: 523 Shop Shark | | Shop Shark Joined: Apr 2011 Posts: 523 | I might be wrong, but I am pretty sure that the USB specification requires 5.0 +- maybe 0.5 VDC output. So cigarette lighter to USB converters should all work even at 6V.
Bob
BobS46
| | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Denny has this habit of solving LOTS of problems we all face.... AFTER we have already spend bazillions of our hard earned dollars on non solutions. Thanks ALOT Denny...
Kidding of course, but lately I have been looking into this very issue because I am into the Arduino Project. It is a very cool solution for dealing with electronic solutions.
In my research, I found that most power supplies have large input spectrum to small output spectrum. Any 5 volt cell charger (DC of course) that plugs into your 12v cig lighter port will work great with 6 volts input and still maintain 5 volts. BUT, its a crap shoot because you never know what the engineer who designed it was thinking. Test it, and chances are good it will work, but its not guaranteed. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | There in lies the problem Deve. We don't know what sort of input voltage regulation the device has built into it's circuitry. As I posted earlier, your input for most SS devices is around 5v. Just take a look at 90% of your wallwarts and once the AC is stepped down it's rectified and regulated at about 5v.
I need to pick up another adapter kit to check out the cell phomes. I know I've got a couple of plug adapter kits around but never can find them when I need them.
I got the ball rollin', so now maybe some of you geniuses can catch it and run with it. dg
| | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | Ding ding ding, we have a winner  PC USB ports were originally spec'ed to 5 vdc and the industry grew from it. If a device can power off of a USB port it'll work in an old antique 6v auto system, negative ground that is  Dave I might be wrong, but I am pretty sure that the USB specification requires 5.0 +- maybe 0.5 VDC output. So cigarette lighter to USB converters should all work even at 6V.
Bob | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I did one of my infamous Tips of the Week concerning stepping down the 5 volt chargers to work with Kids toys that need 3 volts. Its a really cheap way to set the kids up with continuous power without going through batteries like they are going out of style. http://forums.devestechnet.com/foru...ip-of-the-week-16-for-january-17-23-2016Not exactly the same thing, but the circuit that is from Ebay in the article is a miracle worker. You can have 32 volts or less IN and anything between 32 and 0 volts OUT and it runs the same amperage expected. I use that to simulate a 6 volt power supply for running gauges, even heater motors from a 12 volt regulated power supply. That is wonderful about it is, no matter what you input is above the output, the output stays the same. 12 in, 6 out. Or, 9 in, still 6 out. | | | | | Joined: Dec 2013 Posts: 789 Former BMW Rider | | Former BMW Rider Joined: Dec 2013 Posts: 789 | I can tell you firsthand that the step down charger works fantastic! My elliptical machine required 4 Size D batteries. I used an old charger from one of the kid's video games with 9V DC output. The battery terminals have been connected with the step down charger which has been set at 6.2V DC.
No more batteries.......
Thanks for the tip Deve! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | old computer power supplies work well for powering 3V, 5V, 12V DC stuff in the shop and home Bill | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Very true Bill! Lots of people have them lying around too. What the circuit that I suggested in my rant does however is augment that capability to give you all of the in-between voltages with resolutions in the millivolts. Any combination of battery operated stuff can be made battery-less. | | | | | Joined: Jun 2005 Posts: 422 Shop Shark | | Shop Shark Joined: Jun 2005 Posts: 422 | On my 6 volt 53 that works fine with my cell phone... until I true the lights on at whatever RPM... check it out.
Note: I used another adapter for the cigar lighter socket and there was no problem when the lights were turned on??
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Sounds like to much voltage drop due to the draw the f the headlights. I'd first check and clean connections and then evaluate if the cigar lighter is connected and grounded at ideal locations to minimize effects of voltage drop from other loads. | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | The reason all of us have things working with a 6 volt battery is what's called 'TTL' logic. It is based on bi-polar transistors and is 5 volt based. 0 volts is low and 5 volts is high in a binary operation.
