7 members (FAST55, 2-Ton, Reftys49, Eisenholtz, MickeyP, Oswald, Ponchogl), 117 guests, and 3 robots.
Topics128,042
Posts1,055,519
Members48,424
#1149930 02/13/2016 5:32 PM
I really hope this is the right place for this post. I was wondering if you can take the shock mounts from a donor truck and use them to replace the lever shocks on a 1949 chevy 1/2 ton truck. the donor truck would be a 1954 Thanks, if I put this in the wrong place you can beat me with a wet noodle. Steven
1949 Chevy 1/2-Ton ~ Red Truck
More pix on Photobucket
Before cletis breaks out the noodle, the answer to your question is yes.
Carl
Ex Hall Monitor
Ex Hall Monitor
T Online: Content
Just be sure to reinforce the frame where you put the shock mounts. I converted my '38 to tube shocks and we welded bolsters through the frame where the shock mounts fastened. The frame rails weren't designed for the stress in those areas.
I think he'll be OK without reinforcement on his '49. The frame rails didn't change much when they went to tube shocks.
Carl
Thank you so much for the info. I will get the mounts off the 54' and start working on that. Again, thank you, Steven
Or...they are easy enough just to make.
Mine were...see here...
[img]https://farm8.staticflickr.com/7481/15138939274_bbb3861d3c.jpg[/img]
1946 1.5-Ton Chevy Shorty Bus
All my best --- Tango
Tango, that looks easy enough but I have the donor truck so I might as well use those. Oh! the donor truck is a 1954 1st. Some one put a chrys, dodge rear end in it and replaced the front axel with something from the dodge world. One side of the lug nut turn one way the other side the opposite way. Had a v8 in it but all was gone when I got it. Paid 0 dollars for it so hey I kept it. Thanks, Steven By the way they had to cut the axle (front) and weld it up to make it fit. Did not look safe to me.
Ya...I'd be real suspect of an axle that had been cut down. But then, getting the welding & annealing right only matters if you ever plan on driving it.
