Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
6 members (TUTS 59, walter74, 1955 1 Series, 51sub, farmallb, 1 invisible), 42 guests, and 2 robots.
Topics128,005
Posts1,055,256
Members48,418
Guys I have a spindle on 82 p3032 ifs the threads are slightly damaged. Have repair methods.
29 Ford
http://s1078.photobucket.com/user/c...4-BF50-713F5EDE5632_zps8zoj9vfq.jpg.html
31 Ford
55 panel
95 4 door power stroke
49 chevy 2 ton
47 2 ton grain bed w/ hoist.
Many trucks waiting
H Online: Content
If it can't be straightened up with a thread chaser or a thread file, replace the spindle. Do you really want to bet your life on a flaky thread that might let a front wheel come adrift?
http://broadwayrental.com/wp-content/uploads/CIMG0050.jpg
Oven ever had a spindle retreaded but have heard of it . I'm always cautious so measure 20 times cut once
29 Ford
31 Ford
55 panel
49 chevy 2 ton
Many trucks waiting
Sorry hate typing on iPhone
29 Ford
31 Ford
55 panel
49 chevy 2 ton
Many trucks waiting
My shop guy says turn it and rethread. Any opinions ?
29 Ford
31 Ford
55 panel
49 chevy 2 ton
Many trucks waiting
H Online: Content
Are the spindles so scarce or expensive that replacing it isn't an option? There is probably a very good reason that particular thread size was chosen, I'm sure, and creating a one of a kind spindle on only one side by going to a different (smaller) thread is just asking for trouble. I'm going to climb way out on a limb and assume "82 p3032" means it's on a 1982 truck? If it was on a 1902, 1912, 1922, etc. vehicle, I might be able to understand a heroic effort to salvage a part, but not for something from the 1980's.
No common easy to get. Just buddy owns a tool and die shop. We are both farmers also, just build what we need most of time.
29 Ford
31 Ford
55 panel
49 chevy 2 ton
Many trucks waiting
From what I understand of the situation I'd also be looking for a better part.
If it absolutely had to be reused I'd probably turn the old threads off, weld to build up the diameter, and turn true and cut new threads back to stock size.
I'd feel better about a new part than I would the repair.
1952 Chevrolet 3800 pickup
---All pictures---
H Online: Content
Machine the spindle to remove all the threads, weld it up with the proper alloy, anneal, heat treat, and normalize the part, then cut new threads. You're talking about a thousand dollars' worth of labor to salvage a part worth a couple of hundred at most, and a definite "maybe" that it's going to be safe afterwards.
Do you also draw to an inside straight? Let's play some high-stakes poker!
