0 members (), 41 guests, and 7 robots.
Topics128,077
Posts1,056,033
Members48,433
#1149532 02/11/2016 3:10 AM
I am going to install a battery disconnect on my truck and I know that I will lose my radio presets. Read on a precise post that you can buy a computer saver at the FLAPS. Can't I just install a fuse from the battery to the disconnected side. So I still will have a ground an will not lose the presets. The radio has a 15 amp fuse so I thought I would install a 10 amp fuse. Any electrical people out there, will this work? 53 3100 root
root #1149535 02/11/2016 3:12 AM
1953 truck radio?
root #1149543 02/11/2016 3:44 AM
No, after market, retrosound Zuma.
root #1149544 02/11/2016 3:50 AM
no it won't work, the only way to "save presets" is to keep the radio powered [with the correct size fuse] - a radio will always have a ground, even with the battery removed from the vehicle, it's the positive side that prevents the radio computer from losing its mind, and that's why the radio will kill your battery with a period of sitting
root #1149631 02/11/2016 8:22 PM
OK, but if your neg. on battery is disconnected how does the radio keep its ground? I know the radio is grounded to the cab and the cab to a ground to the battery. So, no ground if the battery is disconnected. How do you work around it? root
root #1149639 02/11/2016 9:51 PM
Why don't you ask the seller for a suggestion.
1951 1 Ton Completed
root #1149836 02/12/2016 9:57 PM
I asked retrosound tech. and he did not know. The radio has a consent ON and a key ON only. Also with the key off the radio only draws 3.5 mill amps pre specs. I would think I could go as low as 2.5 or 5 amps. anyone?? root
root #1149842 02/12/2016 10:48 PM
Root...I set you a PM.
Dave
1948 5-window 3100 Chevy
327 V-8 TBI 700R4 Posi 3.73
"Old Blue"
More pix on Flickr
Moderated by  truckernix
