| | | Forums66 Topics128,167 Posts1,057,017 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 19 New Guy | | New Guy Joined: Dec 2011 Posts: 19 | Just purchased a '38 Chevy pickup. Was told that the bed was originally a long bed and had been shortened. Most of the bed side fender holes have been filled. The rear fenders that came with the truck are fiberglass and do not have pre-drilled mounting holes. Are there any drawings available that might show the bed sides with the fender mounting holes? If not, would the best route be to mount the running boards, then work my way back? Any suggestions would be appreciated. | | | | | Joined: Dec 2011 Posts: 19 New Guy | | New Guy Joined: Dec 2011 Posts: 19 | Thanks for the reference links. I also found some excellent information on the MAR-K website. | | | | | Joined: May 2004 Posts: 1,312 'Bolter | | 'Bolter Joined: May 2004 Posts: 1,312 | Depending on whose glass fenders you have, they likely would not fit your hole pattern anyhow. Might be best to fill in existing holes in bed sides and start fresh. Stock rear axle location does not center wheel in wheel opening. Some guys relocate axle a little
