1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
#1142732 01/03/2016 5:16 PM
I'm in the process of changing the lever action shocks on my 1948 3100 over to conventional tubular shock absorbers. I bought a kit from Performance Online, but it came with no instructions for mounting the top brackets for the rear shocks. Can someone out there shoot me a photo of the rear tubular shock absorber installed on the later AD 3100's? Need to get an idea as to where to locate the top bracket. Thanks, Charlie
Maybe this picture of my 52 GMC will help.
rear shock mount
Mike
Hello my friend. I have a question. What kind of paint did you put in the bed? Mine is a pine floor that has been pollied' I want to do it just like yours. Like it came from the factory. Great looking truck. Thanks, Steven
1949 Chevy 1/2-Ton ~ Red Truck
More pix on Photobucket
You may encounter an issue with the surface of the frame where the top shock mount attaches on your '48 frame. I think that they are scalloped in the area where they go. I had that problem and also had trouble finding a point from which to measure to locate the bracket in the proper place and at the proper angle. The way I resolved it was to bolt the shock into the lower shock mount. Once it was tightened up, the shock pointed me in the right direction as to where to locate the top mount.
Carl
