| | | Forums66 Topics128,062 Posts1,055,851 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2013 Posts: 14 New Guy | | New Guy Joined: Sep 2013 Posts: 14 | I'm in the process of changing the lever action shocks on my 1948 3100 over to conventional tubular shock absorbers. I bought a kit from Performance Online, but it came with no instructions for mounting the top brackets for the rear shocks. Can someone out there shoot me a photo of the rear tubular shock absorber installed on the later AD 3100's? Need to get an idea as to where to locate the top bracket. Thanks, Charlie | | | | | Joined: May 2007 Posts: 289 Shop Shark | | Shop Shark Joined: May 2007 Posts: 289 | Maybe this picture of my 52 GMC will help. rear shock mount Mike | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | | | | | | Joined: Jan 2010 Posts: 378 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 378 | Hello my friend. I have a question. What kind of paint did you put in the bed? Mine is a pine floor that has been pollied' I want to do it just like yours. Like it came from the factory. Great looking truck. Thanks, Steven | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | You may encounter an issue with the surface of the frame where the top shock mount attaches on your '48 frame. I think that they are scalloped in the area where they go. I had that problem and also had trouble finding a point from which to measure to locate the bracket in the proper place and at the proper angle. The way I resolved it was to bolt the shock into the lower shock mount. Once it was tightened up, the shock pointed me in the right direction as to where to locate the top mount. Carl
