3 members (WICruiser, Jon G, Ponchogl), 358 guests, and 3 robots.
Topics128,163
Posts1,057,044
Members48,463
I have a 1 ton, changing gears from 5.14 to 4.1
What do I need to have speedo register accurate speed?
What year?
1953
A ratio adapter for $75-$125
The Speedometer Shop (disappeared?) or Jim Carter Truck Parts
Last edited by tclederman; 02/09/2016 6:32 PM. Reason: corrected and provided a link
Go ahead and get the rear end installation done, then do actual measurements using either a GPS or follow a car that you know is accurate at very specific speeds. The Jim Carter website will give you instructions. If you know the true MPH and the incorrect reading on your speedometer, you can have an adapter made that will be very precise. You can test it using the same method after the installation.
Doing the math, you will need an adapter that increases the speedo reading by 20.23% if you do nothing else but change the rear end ratio. If you also plan to change tire sizes, this will make a further change. But calibrate based on the road test, not the math.
Check to see if your tranny already as an adapter on it. Some came from the factory with them (mine did). If so, I recommend that you take it off before you do your calibration testing so that you don't end up installing an adapter to an adapter. Calibrate with your speedo cable screwed directly into your tranny.
The good news is that once you get everything else done, installing the adapter is only about a five minute job.
Matt
mechanical ratio adapters
scroll down - $88 Performance Transmissions and Parts
$150 plus shipping
Also, make sure you have your final wheels and tires installed for best results if you use a GPS check.
24601
24601
Another option: I use the DigiHUD app on my phone. It's free, too.
~ John
1949 Chevrolet 3804
1973 IH 1310 Dump
1963 Kaiser M38A1
2014 Ford E-350 4x4 (Quigley)
