1 members (Truckrolet),
156
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,115 Posts1,056,291 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | Yea ,I broke it. Shattered like glass ,when I was trying to press the cam gear off the 235. Now to find one.I was hoping to have the bottom end all done today.This will slow me down,I paid extra for 2 day shipping,so I would have the new gears ,so I could get it together today.I guess it will be a while .
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Apparently this is what they normally do. I don't know why unless the brass goes brittle somehow. Mine didn't break but I am installing a new one. Because my old one had wear the gear was starting to form a mark on the front plate. | | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | Apparently this is what they normally do. I don't know why unless the brass goes brittle somehow. Mine didn't break but I am installing a new one. Because my old one had wear the gear was starting to form a mark on the front plate. Where did you get the new one. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | PM me your address, I can help.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | The thrust plate is cast steel, not brass, and it's brittle. Pressing an old gear off is a recipie for disaster. We used to break the old fiber gears off with a pry bar and split the gear hub with a chisel, then heat the hub of the new gear and tap it onto the cam with a block of wood and a BFH. An aluminum cam gear can be drilled and tapped for puller bolts- - - -it's junk anyway. Jerry
| | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | The thrust plate is cast steel, not brass, and it's brittle. Pressing an old gear off is a recipie for disaster. We used to break the old fiber gears off with a pry bar and split the gear hub with a chisel, then heat the hub of the new gear and tap it onto the cam with a block of wood and a BFH. An aluminum cam gear can be drilled and tapped for puller bolts- - - -it's junk anyway. Jerry I figured that out the hard way. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | Well I guess there was a variety because with both my 216s and the replacement, they are made of brass. I believe I got mine on Ebay. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | All the 216's I have seen are brass. The steel came later with the full pressure 235's.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Are the thrust plates interchangeable between the 235's and the 194-292 series engines? Jerry
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 194-292 are thinner. I have the correct one ready to go once he gets back with me.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | 194-292 are thinner. I have the correct one ready to go once he gets back with me. Thanks for the part.it is a big help. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 |
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | Are those plates scarce enough to justify tooling up to fabricate them? It looks like a very simple job for a CNC mill, plus a little heat treating to get the right hardness, and a quick surface grinder job for final thickness and finish. Jerry
| | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | as far as I know napa has them readily available, along with the little spacer needed behind certain ones. Delta cam got me one with no problem, however they did lose my brand new cam. The retainers seem to be easy enough to get though . | | | | | Joined: Dec 2007 Posts: 210 Shop Shark | | Shop Shark Joined: Dec 2007 Posts: 210 | Are those plates scarce enough to justify tooling up to fabricate them? It looks like a very simple job for a CNC mill, plus a little heat treating to get the right hardness, and a quick surface grinder job for final thickness and finish. Jerry I was going to do this if I could not find one.I do miss working in a shop that had a CNC punch,CNC brake press,CNC mill,CNC plasma cutter,shear,and iron worker,any steel that I needed.I still have access to a CNC mill and water jet,but prefer not to use them for my own use.After using good tools ,it's hard to go back to doing things by hand. | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | I still do it the hard way- - - -hand cranked machinery and lots of hand-filing and measuring. Of course, most of the high-end firearms are still made by master craftsmen, and the old Mausers and Enfields I work on were made that way close to 100 years ago. Jerry
| | | | | Joined: Jun 2008 Posts: 2 New Guy | | New Guy Joined: Jun 2008 Posts: 2 | What are the pros and cons of the cam gear being Alum.alloy vs. Fiber? I'm replacing my crank pulley on my 56 235, ( it broke loose from the harmonic balancer, wobbled, stretched the rivet holes and made a LOT of noise!!!). Since the whole front of my engine is now exposed, (after one a year on my rebuild), and I have a new fiber gear "in stock", should I replace the alum. alloy cam gear with fiber? Yup, I have studs in the bottom two cover holes so removal will be easy. More noise reduction would be good, but I don't want less precision, performance or longevity. Pros and cons? What say you? | | | | | Joined: Mar 2000 Posts: 1,179 Red dot, center of chest ... | | Red dot, center of chest ... Joined: Mar 2000 Posts: 1,179 | i owned a '67 Firebird many years ago. It had a fiber cam gear. One day the gear shucked its teeth off and dumped tons of fiber fragments in the oil pan. Boy was that fun.
Go with the metal gear. The chain will wear before the teeth do, and the chances of them coming off in pieces are slim to none. | | | | | Joined: Feb 2004 Posts: 29,805 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,805 | The chain will wear before the teeth do What chain? The ones on the tailgate, maybe? Jerry
