3 members (Maybellene, LAJones48, Gazz), 129 guests, and 4 robots.
Topics128,096
Posts1,056,482
Members48,444
#1148527 02/05/2016 9:53 PM
1 Offline
Has anyone recently changed the brake shoes on their 1 ton? I just ordered shoes from rock auto that were supposed to fit and they're about a half inch shorter on each side than the ones I took off.
I'm having a hard time finding ones that fit the 1 ton front. (I haven't touched the rears yet) Any suggestions where to get them?
1942 BK 1/2 Ton Pickup
1954 3800 1 Ton Pickup
H Online: Content
A difference of 1/2" on the circumference of the lining probably won't make a noticeable difference. If you're referring to in/out depth of the lining, that's critical, as would be diameter. 1-ton brakes are pretty scarce items, since the 3800 sort of straddles the fence between a pickup and a full-grown truck. Brake drums are just about impossible to find. It would always be possible to get the old shoes relined if you can find an oldtime brake shop with the equipment to rivet the new linings on or a baking oven to install bonded linings. I'd really prefer a riveted lining if possible.
Stovebolt Photo Moderator
3800 rear shoes are not available. You will need to find a shop to re-line the pairs you already have. More important is looking out for the keeper hardware for those shoes. Watch your parts when you break them down.
Also, if your drums are decent don't cut them. You can't afford to lose parent metal. Good luck - Joe
1947 - 3800 dually known as "Deadwrench"
Link to a few photos
In this world there are givers and takers. The takers eat well, the givers sleep well.
If this is a 1954, the shoes are listed in the Jim carter catalog so I would think they are available. It sounds like you already have them.
1951 1 Ton Completed
1 Offline
Thanks for the help. Yes, I think I may have found them. It's very frustrating and a bit confusing trying to find part for the breaks for this truck. The items that said would fit a 3800 are smaller, including the seals. They're probably for a 3100 1/2 ton. Thanks again.
