| | | Forums66 Topics128,292 Posts1,058,598 Members48,492 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2013 Posts: 9 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 9 | I'm slowly putting together a 66 half ton, with a 350 and 3sp OD. My question is, can I shift this in and out of OD manually? That is without the electric solenoid. I wouldn't mind a second shift lever at all. Thanks for any thoughts or replies Jim | | | | | Joined: May 2001 Posts: 7,438 Extreme Gabster | | Extreme Gabster Joined: May 2001 Posts: 7,438 | No, It must be pulled in with the solenoid. It is simple to wire up. Here's how I wired mine. | | | | | Joined: Apr 2005 Posts: 2,103 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,103 | If you have all the factory components, use them, they work well. There are safeguards built in to prevent damage to internal components such as the reverse lock out. I have seen the result. The relay used in cletis diagram is a good alternative if the factory components are not available. Fred
