Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
6 members (55shaker, Gdads51, Otto Skorzeny, 52Carl, 37 GC, 1 invisible), 139 guests, and 3 robots.
Topics128,292
Posts1,058,593
Members48,492
#1148600 02/06/2016 5:02 AM
I'm slowly putting together a 66 half ton, with a 350 and 3sp OD. My question is, can I shift this in and out of OD manually? That is without the electric solenoid. I wouldn't mind a second shift lever at all.
Thanks for any thoughts or replies Jim
F2036 #1148654 02/06/2016 5:28 PM
No, It must be pulled in with the solenoid. It is simple to wire up. Here's how I wired mine.
F2036 #1148658 02/06/2016 5:39 PM
If you have all the factory components, use them, they work well.
There are safeguards built in to prevent damage to internal components such as the reverse lock out. I have seen the result.
The relay used in cletis diagram is a good alternative if the factory components are not available.
Fred
