4 members (TUTS 59, Jon G, 2-Ton, lumbersawyer), 46 guests, and 3 robots.
Topics128,083
Posts1,056,331
Members48,442
#1148557 02/06/2016 2:00 AM
I am to the point of my T5 install that I need to figure out my shifter. I have an original 4 speed shifter to weld to the T5 shifter. Does anyone have any pictures or pointers of how to weld the T5 shifter to the original shifter? Where to cut, angle of the cuts, measurements or where to weld them together?
49nut
49nut
I am happy with my short throw T5 shifter out of an S10. I modified it to work with a salvage yard shift handle that I found. The 1992 - 1995 S10s with a T5 usually have a short throw shifter. The base is taller than the earlier versions. See this LINK shows how I modified my short throw shifter. If you can't find a short throw version, then THIS LINK shows you how to make a short throw shifter from a regular style. I suggest that you drill the new pivot pin hole with a slight rotation toward the driver which will result in less reaching. It was a fun afternoon project.
I used an original 4 speed shifter welded to the T-5 shifter stub. I used an angle grinder to notch out a 2 inch section out of each and welded them together. Make sure you get plenty of penetration.
Carl
49nut,
Have we met? Maybe I helped you get that T5?
Jay
Lugnutz
We have met. The install is all but complete still need to weld up the perches and get the drive shaft all seams to be going has planned.
49nut
