| | | Forums66 Topics128,148 Posts1,056,813 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2001 Posts: 17 Member | | Member Joined: Aug 2001 Posts: 17 | I'm getting ready to blast and paint the cab of my '51. I'm not sure if and what I should use under the cab. I thought about spray in bedliner or some sort of a scuff-proof paint. Any ideas or does protecting the bottom of the cab matter?
I am also thinking of welding the sheet metal parts inside the cab (for tranny access and master cylinder access) in place as I will be moving the master cylinder to the firewall and cannot see why I would need to access the tranny from inside the cab. Am I overlooking something in doing this?
Thanks! | | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | Big: Just getting ready to do what you are ready to do. I have the cab off on a roll around and going to tip it back on its back. My thought was to spray the bottom of the cab black and then use under coating.
For the hole's I'm sealing the brake door because I'm moving the filler to front. Caan't do floor shift area because I'm going to install floor shifter. But now is the time to do it! If you use bedliner underneath let me know how that turns out. Never thought about that as an option. popcorn The Truth is Out There (Keep us posted) | | | | | Joined: Aug 2003 Posts: 264 Member | | Member Joined: Aug 2003 Posts: 264 | I installed a firewall mounted booster/master cylinder so I welded in patches for the old master cylinder hole. Did the same for the trans access panel, gas tank holes, clutch/brake pedal holes, etc. Plenty of room underneath to access the automatic trans oil cooler lines. The underside of my cab was plastered with some kind of nasty undercoating which did a good job protecting the metal where it stuck. I removed all the old undercoating, then brushed Rustoleum primer and topcoat. Looks good and should protect for a long time. | | | | | Joined: Oct 2001 Posts: 194 Wrench Fetcher | | Wrench Fetcher Joined: Oct 2001 Posts: 194 | I scraped off all the old, hard, undercoating from the bottom of my cab and painted it with Eastwood's Chassis Black paint turned out very well and seems to be very durable. Will see how long it lasts. | | | | | Joined: Jul 2000 Posts: 504 Member | | Member Joined: Jul 2000 Posts: 504 | I painted the underside of my cab and the frame rails with Eastwood Chassis Black.. It is wearing like iron after three years and 8000 or so miles..
Bill M 53 GMC Hydra-Matic
Home Page http://home.comcast.net/~bd97/index.html
When you argue with a fool, two fools are arguing..
| | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Zero Rust. Hard as nails applies like paint.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Jul 2003 Posts: 141 Member | | Member Joined: Jul 2003 Posts: 141 | So, would all of these ideas also apply to the underside of fenders, runningboards, or anything that will face the road?
shoeless | | | | | Joined: Apr 2002 Posts: 142 Member | | Member Joined: Apr 2002 Posts: 142 | A friend of mine took his cab and fenders to the local truck accessory store and had them put the bedliner on the bottom sides.Alot of streetrodders are doing this to prevent starring of the paint,it seems to work . | | | | | Joined: Aug 2001 Posts: 17 Member | | Member Joined: Aug 2001 Posts: 17 | I've thought about the liner under the fenders too but they'll be done later so I figured I'd see how the cab went. Lots of good ideas here- now I'm more confused! I think it will come down to the cost since this project is on a budget.
I like that idea of keeping the paint from starring, very good idea. Thanks for the input! | | |
