3 members (TUTS 59, ShopRag, 1 invisible),
106
Mod | | | Forums66 Topics128,089 Posts1,056,362 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2001 Posts: 142 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2001 Posts: 142 | I am thinking of making an oak "rail" that goes in the bed pockets. Does anyone have picture of various designs? | | | | | Joined: Mar 2003 Posts: 68 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2003 Posts: 68 | Thomas. I dont have pictures but I can try to describe how I did mine. I went to Lowes and bought my lumber. They have oak and its a little high but worth it. Get 4 2x2s that are the right length. Next you need 2 1x4x8's for each side. I also used 2 1x4's to go across the back. Space the 1x4's evenly and bolt them onto the 2x2's where they will seat into the side pockets. Use stainless carriage bolts to bolt everything together and countersink the bolt holes where the nuts screw in to make it flush. I used Drywall screws to attach the back rails to the side ones, then covered each corner with some thin sheet metal attaching them with small shiny wood screws. It takes alot of figurin and time but you will be happy with it. Also make sure you finish the wood with some kind of varnish before you start. Get someone to help you drop it into the side pockets when its done. That oak is heavy and hard to balance by yourself. Trust me, I didnt get help and scratched my bed. I'm such an idiot! | | | | | | Anonymous Unregistered | | Anonymous Unregistered | I used cedar and the uprights were 2x4's that were partially cut down to fit snuggly into the stake pockets. The rest was 1x4 cedar. Carriage bolts to hold it together w/nylock nuts to keep them from vibrating loose. [img] http://www.kinemation.com/Trucks/Images/buddies.jpg[/img] | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | I highlighted the edges of my deck with Malaysian hardwood . http://www.stovebolt.com/gallery/miller_dusty.htm Painted the sides and oiled the deck and top edges. I don't know how to get a pic from the gallery into here , just click on the link to see it . | | |
