7 members (SmalltownTRKGuy, 52Carl, Ponchogl, GradyB, Otto Skorzeny, GRNHydra, 1 invisible), 76 guests, and 0 robots.
Topics128,080
Posts1,055,945
Members48,430
#1147046 01/29/2016 2:08 AM
It's been a while since I've posted anything here, I sold my Big Bolt 41 1 1/2 ton chevy, And recently sold my 48 Fleetline, now I just have my 64 truck here's some pixs, It's not a factory 4x4 it's sitting on a early 70's frame I think 1970...it's 1/2 ton 292 with 4 spd. Been working on it for about 3 yrs..
[IMG]http://i1168.photobucket.com/albums/r491/randycox1/002_zpsgqeas3ah.jpg[/IMG]
[IMG]http://i1168.photobucket.com/albums/r491/randycox1/cut%20out%20caps%20004_zpsyliectju.jpg[/IMG]
[IMG]http://i1168.photobucket.com/albums/r491/randycox1/cut%20out%20caps%20001_zpssnd3gfzz.jpg[/IMG]
fleetline48 #1147054 01/29/2016 2:24 AM
Nice. Many of us in VA/MD area and we would like to see that truck in action.
Are those 16in wheels? What size tires and where are they found? Researching my next set of tires.
~ HB
1962 Chevrolet C10
1962 Suburban
fleetline48 #1147364 01/30/2016 8:38 PM
yes they are 16". The wheels came off my 48 fleetline they are very narrow, The tires are LT 235-16-85-LRE 10Ply, I found them on E-bay for 500.00 free shipping that's about 125.00 a tire,I originally wanted some Bias ply mud tires with big lugs but they were 150.00 a tire plus shipping was waaaaaaaaay too much.. I like the looks of these...My truck has later front Diff's with disk brakes I had to grind alittle on inside of wheel and some on the backside of caliper which doesn't affect anything...I wanted the old style look...
fleetline48 #1147575 02/01/2016 2:31 AM
Nice solid looking truck. I just bought a 64 C10 for parts off of the 292. I am putting a remanufactured 292 in a 53 Chevy wagon, Camaro T5, 10 bolt S10 rear, Fatman suspension, etc.
I have some cab trim from the 64 along with the stainless windshield trim if you would be interested.
I also have a similar truck project to yours. 1959 Chevy Apache Fleetside Deluxe cab short box. Mounted on a mid 80's Chevy truck frame 4x4.
Have fun with your project. These 292's are becoming rare.
Ken
Ken in NY
kb2tha #1147602 02/01/2016 4:10 AM
Ken
I wonder where Tiny is? perhaps he is patrolling somewhere else>
ron
fleetline48 #1147688 02/01/2016 6:27 PM
Ken, the reference above to Tiny is because of the mention of selling parts on this thread. Please take the mentions of parts to the parts for sale section or to a PM.
~ HB
1962 Chevrolet C10
1962 Suburban
kb2tha #1147971 02/03/2016 2:53 AM
The truck by no means was solid It needed rockers inners and outers flooring kick panels, 2 new fenders and inner fenders it still nedds a lot of stuff..
Ken
fleetline48 #1148341 02/04/2016 10:10 PM
Fleet,
Nice! Was looking at the picts and noticed a couple of the steering shaft and column. Why the cut and add? Extension for body lift or something. Could you please explain?
I want to see a vid of the new I6 running!
Cavebull.
cavebull
Stovebolts - so easy even a Cavebull can do it.
https://www.flickr.com/photos/dodsonbrett/collections
fleetline48 #1148342 02/04/2016 10:14 PM
Found the running vid!
Cavebull
cavebull
fleetline48 #1148401 02/05/2016 2:24 AM
Cavebull the steering column was slid closer to the seat because the shaft was too long with that 70 frame and power steering, leaving less gut room,plus it was putting pressure on the rag joint so I cut prolly 2" of the shaft and welded back but used a sleeve and bolted it up in cause the weld broke, I would like to find the early 70's collapsible shaft...I was able to slide the column closer to the dash about 2" when doing this...
fleetline48 #1148679 02/06/2016 9:01 PM
Cool, I am putting a 2 1/2" body lift on my 63" and anticipate a possible steering shaft issue... so that caught my eye. But, yeah, raising the body does the steering wheel wind up in your lap, or do you rub your knuckles on the dash while holding onto the the wheel? Not to mention as you said possible tension on the rag joint.
Cavebull
cavebull
fleetline48 #1148705 02/07/2016 12:03 AM
You know I'm not sure about that with the body lift,I know a lot of people go that route.
