5 members (Hanks custodian, KEVINSKI, Southerntruck, Gray_Ghost, Hotrod Lincoln), 148 guests, and 1 robot.
Topics128,162
Posts1,056,932
Members48,458
#1145871 01/21/2016 3:28 PM
Hello Everyone, I just acquired a set of unison seats for a 1954 Chevy 3100 RPO 264. It does look like I'm missing one key component and that would be the frame for the passenger side seat cushions and the filler piece for the driver side base.
Could someone help me understand how the passenger side mounts and would a driver front seat for the suburban work as then frame?
Scott
Chevytruckdaddy
The pass side has two "L" shaped brackets that bolt across the top of the standard welded in seat skirt. They provide the mounting point for the bottom of the pass side seat back. The top hangs on brackets that bolt to the back of the cab. The driver's side seat bolts into the bottom of the cab in holes that you drill where there are already marking spot indentions if that makes sense to you. They also bolt to holes that are already in the front to the seat skirt. As you mentioned, the filler plate screws to the seat skirt and fills the gap below the seat adjuster. I think I probably have pictures to make it more clear if you want to send an e-mail address in a private message.
Thank you Greg I got my seats yesterday... Your pictures are awesome...
Chevytruckdaddy
