0 members (), 123 guests, and 8 robots.
Topics128,186
Posts1,057,211
Members48,465
I'm using a ford 9" on my 55 3200. Is there an aftermarket spare tire carrier set up that will accommodate my spare tire on the fender? Do I just modify the existing mount to hold my spare tire? Small ford bolt patter 5 x 4.5.
Thanks in advance
Admin for Turbobuick.com
87 GN, and new toy: 1955 Chevy 3200 pickup, soon to have: 383, Cola crank, Childs/Albert 6 inch rods, Brownfield heads, 10:1 KB hypers, CompCam 284 Extreme Energy, Tilton Plate transmission realignment and built Turbo400.
gofstbuick, I modified mine from a 6 hole pattern to fit my 5 X 4.75 chevy wheel. I left the top one in and ground the other 2 off and center the wheel and redrilled the holes. Put in new studs and tacked the back side so they would not spin. Looks just like the original. 53 3100 root
Thank you
