| | | Forums66 Topics128,049 Posts1,055,634 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2004 Posts: 19 Junior Member | | Junior Member Joined: Sep 2004 Posts: 19 | Does anyone know of a product that can be applied to raw metal that will allow welding and still help prevent rust in areas that will be closed off after welding? I won't be able to paint in those areas after welding.
Thanks for any help.
Just another new hobby... but learning fast.
| | | | | | Anonymous Unregistered | | Anonymous Unregistered | I paint my pieces with Zero Rust and let them cure prior to welding them in place. Also, prior to closing off an area, such as an inner cowl, I hit it again with more ZR. After I am done welding the new piece in place and grinding I spray the worked areas with ZR. After letting it cure I them seam seal the patch. In my opinion that is about all you can do without spraying everything with undercoating or bed liner material. | | | | | Joined: Jun 2003 Posts: 331 Member | | Member Joined: Jun 2003 Posts: 331 | I've used oxi solve rust remover on bare metal after welding. Just spray it on and leave it. When I get back to welding I just use a damp cloth to clean it up and reinstall when done for the day. I don't know what is is but every time someone walks in the shop they have to touch the bare metal, this works for elimenating finger prints. Ive heard that Por15 works well too | | | | | Joined: Sep 2003 Posts: 66 New Guy | | New Guy Joined: Sep 2003 Posts: 66 | You can also use a weld through primer before welding for some added protection. It is available in spray cans.........Dale
1939 GMC 1953 HD PANHEAD 1930 Chevy 3 window coupe
