Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
6 members (Peggy M, Waveski, 55shaker, Joe W, TUTS 59, RBs36), 524 guests, and 1 robot.
Topics126,777
Posts1,039,282
Members48,100
Most Online2,175
Jul 21st, 2025
#1145930 01/21/2016 9:19 PM
I'm restoring a 1950 GMC 1-Ton (FC253-19637) produced near the end of the run. Purchased from a guy who could not complete the project and disassembled down to the bare frame. What is missing is the rear upper shock attachment brackets. In 1950 changes were made to tube shocks but not sure if done to all models. The 1947-1954 Chevy Factory Assembly Manual Section 4, Sheet 4.02 shows the same bracket as on my axels. However, the bracket is too narrow for new shocks. I’m needing help determining what my rear shock configuration should be to match original. Thanks, Frank
I too am curious about those upper shock brackets. I've not consciously seen any. Have seen plenty of the brackets on the rear axles though.
Grigg
1952 Chevrolet 3800 pickup
---All pictures---
I believe my 52 has the brackets your are referring to. I will get a picture of both sets later and forward on to you.
Mark
1952 GMC 9430 one ton pickup, a work in progress
1952 1-ton pictures on Photobucket
I looked in the GMC parts book last night and they look like the same as upper front shock brackets but mounted to a C shaped bracket to bring them inside the frame clear of the frame flanges.
I can add pictures and part numbers next week.
If someone does have those adapter brackets they'd be easy to measure and copy. Then scavenge some more front brackets to use.
Grigg
---All pictures---
My truck does have the C shaped support bracket but the shock mount has been removed leaving three rivet stubs behind. I assume they did this when they installed the dump box, which I have removed. I can get you dimensions if you like?
http://s1142.photobucket.com/user/52_Ton/library/Suspension?sort=3&page=1
Mark
Yep, that's the bracket.
If you could do a real nice job with dimensions and or a good drawing they could be duplicated by most steel fab shops with a press brake.
If anyone has a bracket removed I'd be glad to measure it and produce a professional like shop drawing.
---All pictures---
Franklin's 50 #1148691 02/06/2016 11:28 PM
I took some measurements and did up a primitive sketch with dimensions. I also added a couple more pictures.
The rivets on top have been cut off which at this point made it difficult to get the dimension of them.
Mark
Moderated by  Dusty53
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.337s Queries: 14 (0.130s) Memory: 0.6211 MB (Peak: 0.6917 MB) Data Comp: Zlib Server Time: 2025-09-22 16:58:12 UTC
Valid HTML 5 and Valid CSS
