0 members (), 61 guests, and 1 robot.
Topics128,049
Posts1,055,743
#1146496 01/25/2016 3:59 AM
2 speed will not shift lo to hi or hi to lo. If I switch the vacuum lines one side works, but the other side does not. Is there a valve between the switch and the actuator. My Thinking is one side of the valve working the other not. Already took the actuator apart and everything looks good including diaphram. I have a 1963 Chevy 2 ton that I still haul grain with. The 292 six engine works great when the 2 speed axle works. NOT SO GOOD WITHOUT. To confirm, The 2 speed will shift if I manually change the hi side to the lo side or vice versus. One line works, the other not. Thanks for any help. IF it is a valve, is one available anywhere?
gospel1 #1146513 01/25/2016 8:42 AM
Welcome to the Stovebolt wave
Sounds like the Vacuum Switch located near the trans is not working. Could be an internal blockage in the switch or the push/pull cable has pulled out of the switch housing.
If a replacement can't be found you could replace the control valve with a suitable electric solinoid valve (12vdc, 3 or 4 way) and put a modern Eaton 2-speed electric switch on the gear shift lever making it electric over vacuum control.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
gospel1 #1146726 01/27/2016 12:09 AM
Check out this post:
https://www.stovebolt.com/ubbthread...switch_rebuild_for_late.html#Post1124126
I had a similar issue and replaced the switches as Mike recommends. All from Ebay, part numbers listed in the thread above.
gospel1 #1146758 01/27/2016 3:49 AM
The 2 speed diff. on my 46 C.O.E. wouldn't shift with the vacuum switch,but would manually,(it's factory mounted on the dash). And after fighting it for months,I started feeding the switch WD-40 by letting the vacuum pull it in and it started working but leaked and then stopped leaking and has been working great for years! It down shifts smoother than the transmission.
