| | | Forums66 Topics128,014 Posts1,055,324 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2000 Posts: 114 Member | | Member Joined: Sep 2000 Posts: 114 | My dask paint is faded. Do I need to sand or strip it off, or can I rough it up with some 200 grit and paint over it? This is for a 52 Burb. Thanks! :p
Jim
| | | | | Joined: Dec 2001 Posts: 1,248 'Bolter | | 'Bolter Joined: Dec 2001 Posts: 1,248 | I don't know that you want to use 200 grit, probably would be better to use 320 or 400 grit. If original paint is sound, should not be a problem to repaint over it.  | | | | | Joined: May 2001 Posts: 71 Shop Shark | | Shop Shark Joined: May 2001 Posts: 71 | Yes they recommend 400-600 grit before painting. If the paint is fine you can just use that before spraying the new paint.
'53 Chevy truck 1/2 ton
