5 members (78buckshot, Jeff Ogden, Otto Skorzeny, KingG, 1 invisible), 39 guests, and 5 robots.
Topics128,012
Posts1,055,316
Members48,419
#114650 01/04/2002 12:39 AM
My dask paint is faded. Do I need to sand or strip it off, or can I rough it up with some 200 grit and paint over it? This is for a 52 Burb. Thanks! :p
Jim
#114651 01/04/2002 2:22 AM
I don't know that you want to use 200 grit, probably would be better to use 320 or 400 grit. If original paint is sound, should not be a problem to repaint over it. smile
#114652 01/06/2002 4:48 AM
Yes they recommend 400-600 grit before painting. If the paint is fine you can just use that before spraying the new paint.
'53 Chevy truck 1/2 ton
