4 members (Hotrod Lincoln, Canadian Dump, Dennys28, Phak1), 130 guests, and 4 robots.
Topics128,165
Posts1,056,987
Members48,458
they appear to be the same but I have never seen two side by side.
Hoods are not the same. 41-46 are longer.
they are definitely different . what year is your truck? just wondering because i just went through my truck and have a 41-46 hood ,decent shape needs a good home , my truck was changed to a 39-40 front end and my hood needs work ,lots of it! i wish they were interchangable!
cliff
39 chevy suburban w/250-6cyl "Valve in head means ahead in value"
redwood city cliff
Have you tried laying that 41-46 top hood on your 39-40 front end to see if you can cut the rear to fit ?
no i havent tried that . aren't the nose and grill configuration majorrly different . ill get back to you on that one!
cliff
Too bad...I just saw a perfect 41-46 hood with sides and trim at the Jefferson, WI fall swap meet/Show. The Guy wanted $160 for it. i was tempeted try wheeling and dealing with him but just didn't have the energy. My hood has a couple dents that can be pounded out pretty easily so I didn't have a lot of motivation either. Keep and eye out there. They pop up on e-bay once & a while.
Tim Sheridan
1947 First Series Chevy 1/2-Ton
"Liberty Series" - "Art Deco" - Whatever you'd like to call it.
are you needing a 41-46 hood ?i need a 39-40 hood we could swap!
cliff
