| | | Forums66 Topics128,164 Posts1,056,977 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2002 Posts: 127 Wrench Fetcher | | Wrench Fetcher Joined: Aug 2002 Posts: 127 | they appear to be the same but I have never seen two side by side. | | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | Hoods are not the same. 41-46 are longer. | | | | | Joined: Feb 2003 Posts: 21 Member | | Member Joined: Feb 2003 Posts: 21 | they are definitely different . what year is your truck? just wondering because i just went through my truck and have a 41-46 hood ,decent shape needs a good home , my truck was changed to a 39-40 front end and my hood needs work ,lots of it! i wish they were interchangable!
cliff 39 chevy suburban w/250-6cyl "Valve in head means ahead in value"
| | | | | Joined: Nov 2001 Posts: 481 Shop Shark | | Shop Shark Joined: Nov 2001 Posts: 481 | redwood city cliff Have you tried laying that 41-46 top hood on your 39-40 front end to see if you can cut the rear to fit ? | | | | | Joined: Feb 2003 Posts: 21 Member | | Member Joined: Feb 2003 Posts: 21 | no i havent tried that . aren't the nose and grill configuration majorrly different . ill get back to you on that one!
| | | | | Joined: Mar 2001 Posts: 629 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 629 | Too bad...I just saw a perfect 41-46 hood with sides and trim at the Jefferson, WI fall swap meet/Show. The Guy wanted $160 for it. i was tempeted try wheeling and dealing with him but just didn't have the energy. My hood has a couple dents that can be pounded out pretty easily so I didn't have a lot of motivation either. Keep and eye out there. They pop up on e-bay once & a while.
Tim Sheridan 1947 First Series Chevy 1/2-Ton"Liberty Series" - "Art Deco" - Whatever you'd like to call it. In the Gallery | | | | | Joined: Feb 2003 Posts: 21 Member | | Member Joined: Feb 2003 Posts: 21 | are you needing a 41-46 hood ?i need a 39-40 hood we could swap!
