1 members (UtahYork),
114
0
Mod | | | Forums66 Topics128,274 Posts1,058,430 Members48,489 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2002 Posts: 272 Shop Shark | | Shop Shark Joined: Jun 2002 Posts: 272 | Will paint stripper put a dent  in filler? Or will I have to grind/sand it out? I originally intended to sand the whole thing but someone at work mentioned stripper. | | | | | Joined: Mar 2001 Posts: 259 Member | | Member Joined: Mar 2001 Posts: 259 | Yes paint stripper will eat into the filler but only so far.....then you have to apply more stripper and do more scraping.
Joe
| | | | | Joined: Jul 2004 Posts: 24 Member | | Member Joined: Jul 2004 Posts: 24 | I am actually getting some Aircraft Stripper to strip down my truck. Hopefully I will make some progress by this weekend, but I was told that it would work great on filler. I was told the regular stripper wasn't that good and to make sure I got Aircraft Stripper. Let me know how yours is going...I will do the same.
Stella 1970 Monte Carlo 355 1987 Camaro IROC-Z 305 TPI 1955 Chevrolet Second Series GET-R-DONE | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | I think most strippers create a bulge, not a dent.
54 3100 with 235 62 flatbed dump C60 with 261
| | | | | Joined: Jul 2004 Posts: 24 Member | | Member Joined: Jul 2004 Posts: 24 | Originally posted by Tony M: I think most strippers create a bulge, not a dent. [img] http://www.beatlelinks.net/ubb/smilies/nono.gif[/img]
Stella 1970 Monte Carlo 355 1987 Camaro IROC-Z 305 TPI 1955 Chevrolet Second Series GET-R-DONE | | | | | Joined: Jan 2002 Posts: 398 Member | | Member Joined: Jan 2002 Posts: 398 | Yep, you want Aircraft Stripper . It does a decent job of removing filler, but as mentioned above, you will likely need more than one application and scraping to get it all out. Hope this helps. Regards, Wannabe
"Don't expect anything and you'll never be disappointed"
| | | | | Joined: Jan 2001 Posts: 198 Member | | Member Joined: Jan 2001 Posts: 198 | you can always put a good coat of stripper on and then duct tape a bag over the area so the stripper does not dry out and the remove the bag an hour or so later... A wire brush on the grinder also does wonder on the loosened paint, just dont do it with no T-shirt on that stripper burns when it gets stuck in your chest hairs... | | | | | Joined: Dec 2001 Posts: 1,745 Member | | Member Joined: Dec 2001 Posts: 1,745 | Some strippers like to do a little grinding but it depends on locals laws if it is allowed or not.
| | | | | Joined: Jul 2004 Posts: 24 Member | | Member Joined: Jul 2004 Posts: 24 | Well..I played with the stripper for the first time tonight (HUSH TONY!  ). It is pretty cool! There are some spots that I didn't get too good.  BUT, I also have some grinding to do on some rust areas and some repair work, so I will get it. That aircraft stripper is fun! Yeah...I know...takes little to entertain me, but was cool coming off and seeing the coats of primer and paint under it (I also know it won't be fun anymore once I do more then just the hood)  . Here are pics of my hood...not done..but I have to get up before 5am so I called it a night... http://clubs.hemmings.com/clubsites/ppgma/truck/day3.html
Stella 1970 Monte Carlo 355 1987 Camaro IROC-Z 305 TPI 1955 Chevrolet Second Series GET-R-DONE | | | | | Joined: Jan 2003 Posts: 687 Shop Shark | | Shop Shark Joined: Jan 2003 Posts: 687 | UH Stella you didn't get any stripper on that car by accident did you. Look like a speckled puppy in the morning.
popcorn The truth is Out There (Keep the pictures coming it gets us lazy ones going) Ben | | | | | Joined: Jul 2004 Posts: 24 Member | | Member Joined: Jul 2004 Posts: 24 | hehe..no....something was on the lense. :rolleyes: I need a new camera.
Thats my hubby's Trans am (hubby is a pontiac guy)..I am stripping his Quarter this weekend. He wants me to paint it a 'intense blue' for him..but I refuse to do it until I can drive around in all black primer...I just love black primer. I know..I am a meany ain't I :p
Stella 1970 Monte Carlo 355 1987 Camaro IROC-Z 305 TPI 1955 Chevrolet Second Series GET-R-DONE | | | | | Joined: Mar 2004 Posts: 14 Junior Member | | Junior Member Joined: Mar 2004 Posts: 14 | Body filler can be removed in a variety of ways.
Grinding(sanding) is effective but makes a lot of dust and noise.
Stripper works, too, but takes a lot of applications if the filler is thick, and it's messy.
If there's a lot, and it's thick, I like to use heat, such as a propane torch, or a mild flame from an oxy-acetylene set up. No dust, and no gooey mess from the stripper, but it stinks, instead. It works pretty fast, and doesn't require enough heat to do any damage
Tim Stellar Antique Auto Restorations
Tim
