3 members (baldeagle, Eisenholtz, NJC), 119 guests, and 2 robots.
Topics128,037
Posts1,055,469
Members48,424
#114603 07/06/2004 11:48 PM
I
I Offline
Will paint stripper put a dent wink in filler?
Or will I have to grind/sand it out?
I originally intended to sand the whole thing but someone at work mentioned stripper.
Don't you know who I think I am?
I've been thinkin' about freaking out. If I could just find the time.
http://community.webshots.com/user/ifrizlfri
#114604 07/07/2004 1:44 AM
Yes paint stripper will eat into the filler but only so far.....then you have to apply more stripper and do more scraping.
Joe
#114605 07/09/2004 5:19 PM
7
7 Offline
I am actually getting some Aircraft Stripper to strip down my truck. Hopefully I will make some progress by this weekend, but I was told that it would work great on filler.
I was told the regular stripper wasn't that good and to make sure I got Aircraft Stripper.
Let me know how yours is going...I will do the same. wink
Stella
1970 Monte Carlo 355
1987 Camaro IROC-Z 305 TPI
1955 Chevrolet Second Series
GET-R-DONE
#114606 07/09/2004 6:42 PM
I think most strippers create a bulge, not a dent.
wink
54 3100 with 235
62 flatbed dump C60 with 261
#114607 07/10/2004 5:47 PM
7
7 Offline
Quote
wink
[img]http://www.beatlelinks.net/ubb/smilies/nono.gif[/img] wink
Stella
GET-R-DONE
#114608 07/13/2004 10:49 PM
Yep, you want Aircraft Stripper . It does a decent job of removing filler, but as mentioned above, you will likely need more than one application and scraping to get it all out. Hope this helps.
Regards,
Wannabe smile
"Don't expect anything and you'll never be disappointed"
#114609 07/14/2004 3:10 AM
you can always put a good coat of stripper on and then duct tape a bag over the area so the stripper does not dry out and the remove the bag an hour or so later... A wire brush on the grinder also does wonder on the loosened paint, just dont do it with no T-shirt on that stripper burns when it gets stuck in your chest hairs...
#114610 07/14/2004 4:05 AM
Some strippers like to do a little grinding but it depends on locals laws if it is allowed or not.
54 3100 with 235
#114611 07/15/2004 2:00 AM
7
7 Offline
Well..I played with the stripper for the first time tonight (HUSH TONY! wink ). It is pretty cool!
There are some spots that I didn't get too good. frown BUT, I also have some grinding to do on some rust areas and some repair work, so I will get it.
That aircraft stripper is fun! Yeah...I know...takes little to entertain me, but was cool coming off and seeing the coats of primer and paint under it (I also know it won't be fun anymore once I do more then just the hood) wink .
Here are pics of my hood...not done..but I have to get up before 5am so I called it a night...
http://clubs.hemmings.com/clubsites/ppgma/truck/day3.html
Stella
GET-R-DONE
#114612 07/15/2004 2:07 AM
UH Stella you didn't get any stripper on that car by accident did you. Look like a speckled puppy in the morning.
popcorn The truth is Out There (Keep the pictures coming it gets us lazy ones going) Ben
#114613 07/15/2004 2:14 AM
7
7 Offline
hehe..no....something was on the lense. :rolleyes: I need a new camera.
Thats my hubby's Trans am (hubby is a pontiac guy)..I am stripping his Quarter this weekend. He wants me to paint it a 'intense blue' for him..but I refuse to do it until I can drive around in all black primer...I just love black primer. I know..I am a meany ain't I :p
Stella
GET-R-DONE
#114614 07/16/2004 4:32 AM
Junior Member
Junior Member
Body filler can be removed in a variety of ways.
Grinding(sanding) is effective but makes a lot of dust and noise.
Stripper works, too, but takes a lot of applications if the filler is thick, and it's messy.
If there's a lot, and it's thick, I like to use heat, such as a propane torch, or a mild flame from an oxy-acetylene set up. No dust, and no gooey mess from the stripper, but it stinks, instead. It works pretty fast, and doesn't require enough heat to do any damage
Tim
Stellar Antique Auto Restorations
Tim
