0 members (),
155
Mod | | | Forums66 Topics128,167 Posts1,057,018 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2008 Posts: 283 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 283 | 56 3100 235 column shift w/overdrive. My oil pressure fluctuates 30 to 55 when I drive in overdrive, but stays steady 30-35 driving not in overdrive. I never noticed this happening before, maybe it's always been that way, but Is that normal? Can't imagine that driving in overdrive would have that kind of affect.
Dale | | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | It wouldn't have effect on the oil pressure itself. If the gauge is electrical it could effect the operation of it. Could be a bad ground between the engine & body or the instrument panel. If it is a mechanical gauge I can't imagine how it would effect it. Hook up a master gauge & try it. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: Jan 2001 Posts: 1,424 ODSS President | | ODSS President Joined: Jan 2001 Posts: 1,424 | Well your foot doesn't have a constant pressure, the terrain is a constant variable. The best move I ever made was to install a Vacuum gauge, completely changed how I drive my '49 1/2 ton with a '69 3sp+od. I spend MUCH less time in od, I just pay attention to 'the green zone' the area of greatest efficiency.
~ Cosmo 1949 Chevy Half Ton Rocinante, like Don Quixote, he is awkward, past his prime, and engaged in a task beyond his capacities. "...my good horse Rocinante, mine eternal and inseparable companion in all my journeys and courses." ...Don Quixote, Cervantes "If you come to a fork in the road, take it."...Yogi Berra "Rudeness is the weak man's imitation of strength." ...Eric Hoffer
| | | | | Joined: Mar 2008 Posts: 283 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 283 | Well it looks to me like I have a mechanical oil gauge. Tube travels from a combined oil filter hose/oil gauge tube fitting at the base of the engine to the oil gauge. Don't have a "master gauge" and a quick call says flaps don't carry them either - kinda laughed at me "old school" he said, "try Snap On". Must be a specialty tool? Unless I'm missing something (entirely possible) and that oil gauge is still somehow electrical (it does seem electrical would be the only way the reading would differ od to not od, as you said). So I will start checking ground wires again. Have had that trouble in the past. Thanks for the help! Dale | | | | | Joined: Mar 2008 Posts: 283 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 283 | You know Cosmo, what you say makes a lot of sense. I am not overly fond of OD unless I am traveling farther and want to go faster. For that it's great. Around here locally, most of my driving is just local speeds, and I like the feel of the engine helping me slow down when I'm off the gas pedal. Don't know why, I just do. Lots of vacuum gauges out there though. Are any of them better or all pretty much the same? Only want to do it one time so should get a good one. Thanks for your thoughts ---- Dale | | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | The joke is on the guys at the FLAPS! The gauge Cosmo is referring to is simply an aftermarket mechanical gauge- - - -I'll bet they have one right on the shelf! Just disconnect the line going to the dash from the T fitting on the side of the block, plumb in a new gauge line temporarily, duct tape the gauge to the windshield wiper, and go for a test drive. Then check to see if the pressure reading is the same with the new gauge! Jerry
