7 members (Donf, Hanks custodian, Cosmo, Gray_Ghost, treegrower, Bill Hanlon, 1 invisible), 105 guests, and 1 robot.
Topics128,080
Posts1,055,956
Members48,430
#1144448 01/13/2016 1:01 AM
Does anyone know what the difference is between a standard and deluxe heater in a 56 Chevy truck? The heater core has a control valve attached to it that has a coiled tube on it. Very rusty just wondering it's purpose and if it is needed. Thanks.
see the link in my tag line for TF heaters for pics - that 'control valve' is a Ranco valve, meant to control water flow to a set temperature - found on the deluxe heaters, which have a control panel with a temperature slide control, the standard heater only has a variable fan switch knob
The Deluxe Heater is also known as a "fresh air heater" as it can be set to bring fresh air into the cab, the Standard Heater only recirculates cab air.
The defrost and heat selection on the Standard Heater is do by flipping a lever down on the heater unit.
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
Moderated by  ndkid275, Phak1
