3 members (RonG, Forty9, Jon G), 126 guests, and 2 robots.
Topics128,163
Posts1,056,964
Members48,458
Hood insignia and side fender insignia's on '56 3100 require some painting (in indented areas) of a dull black color, and an insignia red color on the bowtie. What is the best way to paint these areas--mask and spray or paint by hand? Appreciate your ideas. smile
Use sign painters paint, it sticks to smooth sufaces. Steady hand & brush, or airbrush/masking tape/X-acto knife. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
Sign painters paint--great idea! Is this paint available at any paint store? Thanks for the reply!
Brian56
The paint I used was semi-gloss in a spray can from the local paint and body supply outlet.
I did my emblems, locking gas cap, after-market step plates, etc. by rough masking the areas I didn't want painted, spray painting, and then using thinner on multiple folded paper toweling (that way you have an absorbent, pseudo-flexible surface that won't bend down into the painted areas) over the raised areas after the paint had set but was not totally dry.
That way you have a nice smooth blended edge that doesn't look masked. The hardest part was the hood ornament. That one was a PIA.
I did my Offenhauser cast aluminum valve covers the same way after painting them with a brush--POR 15 engine paint.
Just take your time.
1956 Chevy 3100
261/700r4 (formerly 3 speed OD)
More pix on Photobucket
Great information 56picup! Thank you. wink
