1 members (TexasA&M48Truck),
190
Mod | | | Forums66 Topics128,047 Posts1,055,532 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2014 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2014 Posts: 44 | I have Googled this for awhile but can't find the answer.....I have a 59 Apache shortbed stepside, 235 engine. The original radiator is still on it but the core has disintegrated and I was going to replace the whole thing. Here are the specs: Harrison 3135652 R-11A 58L For the replacement, do I need to go with 2 or 3 core, or does it make a difference? I found these on eBay: Radiator 1 Radiator 2 Radiator 3 Thanks! | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 3 core will provide more cooling, but the extra expense shouldn't be necessary for a healthy 235
Bill | | | | | Joined: Jan 2014 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2014 Posts: 44 | Thank you Bill
Places like Classic Parts and LMC have replacement radiators, but they are alot more expensive than the aluminum ones that I listed on eBay. Is one alot better than the other? | | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | Why not take it to your local radiator shop and get it recored? if it was originally 2 row, replace it with a 2 row core.
1959 3100 Apache Fleetside
| | | | | Joined: Jan 2014 Posts: 44 Wrench Fetcher | | Wrench Fetcher Joined: Jan 2014 Posts: 44 | I talked to my local radiator shop.....it would cost $500-$600 to get it recored.....would be much cheaper to buy a new one.
I took it to a local automotive shop that specializes in classic cars/trucks. They have worked on it before. They are going to order me another radiator.
Thanks | | |
