2 members (Cosmo, Wayne67vert), 43 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#11450 01/19/2004 5:53 PM
Junior Member
Junior Member
I have the original sm420 in my 52 chevy pick up and need to know the number of teeth on the speedometer drive gear. I know the number of teeth on the driven gear. I want to avoid opening up the transmission, so if anyone can help me I would appreciate it. I want to get a ratio adaptor and need to know the number of drive/driven teeth.
Thanks, Bill
#11451 01/19/2004 6:42 PM
I have a couple speedogears which do not have the same number of teeth. I'm currently using one which has 12 teeth. I have one in storage that has 11.
I've been able to remove my gear by putting the tranny in neutral and while removing the speedo gear the big gear inside turns. Otherwise what about opening up the bell housing so you can turn the driveline (assuming yours in enclosed) while unthreading the speedogear. This way you can confirm the number of teeth you have.
Craig
#11452 01/20/2004 1:41 AM
If it is a 1/2 ton w 4spd. trans. the speedo gearset is 4 and 12 teeth. No adapter nessasary.
