| | | Forums66 Topics128,081 Posts1,055,955 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#11450 01/19/2004 5:53 PM | Joined: Mar 2001 Posts: 20 Junior Member | | Junior Member Joined: Mar 2001 Posts: 20 | I have the original sm420 in my 52 chevy pick up and need to know the number of teeth on the speedometer drive gear. I know the number of teeth on the driven gear. I want to avoid opening up the transmission, so if anyone can help me I would appreciate it. I want to get a ratio adaptor and need to know the number of drive/driven teeth. Thanks, Bill | | |
#11451 01/19/2004 6:42 PM | Joined: Jan 2002 Posts: 2,839 'Bolter | | 'Bolter Joined: Jan 2002 Posts: 2,839 | I have a couple speedogears which do not have the same number of teeth. I'm currently using one which has 12 teeth. I have one in storage that has 11.
I've been able to remove my gear by putting the tranny in neutral and while removing the speedo gear the big gear inside turns. Otherwise what about opening up the bell housing so you can turn the driveline (assuming yours in enclosed) while unthreading the speedogear. This way you can confirm the number of teeth you have.
Craig My '50 Chevy 3100 5 window, '62-235cu, 3:55 rear My truck ....... Respect The Rust If I'm not working on my truck, '65 m00stang or VW camper, I'm fishing with the wife or smoking Salmon.
#11452 01/20/2004 1:41 AM | Joined: Jul 2002 Posts: 165 'Bolter | | 'Bolter Joined: Jul 2002 Posts: 165 | If it is a 1/2 ton w 4spd. trans. the speedo gearset is 4 and 12 teeth. No adapter nessasary. | | |
