| | | Forums66 Topics128,128 Posts1,056,666 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2015 Posts: 47 Wrench Fetcher | | Wrench Fetcher Joined: May 2015 Posts: 47 | Hi everyone, Did all 235s have dipstick tubes? My project truck's engine came with a shorty dipstick and no tube, so I started researching and actually bought Deve's dipstick tube. Now, I am looking for dipsticks, and have seen guys on ebay selling some as "correct for 235s with no dipstick tube". What gives?  | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | Most likely you could use a stick/gauge with no tube, if the stick/gauge is the correct length for your year/type of 1941-1962 235 (with standard pans for each year). A tube was "standard" equipment on domestic trucks. Here are some of the gauge/stick and tube lengths from 1941 to 1957 (58-62 235/261 should/might match the 1957 lengths/parts). | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Q.Did all 235s have dipstick tubes? A.I would say no because some earlier car, COE and Double Duty engines came with just a short dipstick. According to MPC. 1929 - 1957 Chevrolet Master Parts & Accessories Catalog 1953-57 Six Cylinder Engine Assy. Cross Section Typical Dipstick,Rod,Gauge;47-55, Commercial Utility, 15 3/32", Measured from under washer to bottom end. part #3701556 Tube;47-57, Commercial Utility, 8 7/64", part #3705397 Note: On jobs prior to 1955 cut to 6 3/4" | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | Yeah, the tube is correct for most 235/261 engines of the era, but I agree dipsticks are harder to find. Put an ad in the Parts Wanted section here. I have always had pretty good luck. | | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 |
1959 3100 Apache Fleetside
| | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | Anybody got a good suggestion on how to get a dipstick tube out of my old 235 without damaging it?
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I always drop a long 5/16" bolt in it so it does not crush, then grab it with vice-grips and twist and lift.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | In my experience, its pretty hard to NOT damage it anyway. It depends on how stubborn it is. The dipstick fits in surprisingly tight already, so you don't have a lot of room for mistakes. | | | | | Joined: Dec 2011 Posts: 241 'Bolter | | 'Bolter Joined: Dec 2011 Posts: 241 | I put some heat to the block around the tube which helped me get mine out. | | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | Thanks for the ideas, I appreciate them.
