4 members (Gdads51, 1955 1 Series, KEVINSKI, 1 invisible), 105 guests, and 2 robots.
Topics128,170
Posts1,057,033
Members48,458
Howdy all.
Working on the subject engine / exhaust combo in my 59 Burb. I want to go rams head exhaust manifolds. I just picked up a very inexpensive set of manifolds (3747038 and 3749965) that I believe are 1.9 inch. I'm not a high performance speedster. However, are these 1.9ers going to restrict my capabilities to a major degree?? Appreciate your input.
Thanks! Maddog
Unless you're planning to run some outrageous RPM, I doubt if you'll notice any problems at all. I've run the small-pipe ram's horns on 350's at 6K+ RPM on the dyno, and they could have handled more speed easily. The big ones (2 1/2" pipes) were used on the 300 HP 327's and some of the high performance 350's, and it was difficult to tell the difference in performance between them and most of the headers we ran during dyno testing.
My buddy runs them on a somewhat hi-performance 350 and hasn't complained about anything except the "JetHot" coating not holding up.
I have also spent a lot of dyno time with sbc and had the same results Jerry mentioned. Dynos had mass air flow sensors for years before cars and something I've noticed is larger exhaust kills some low end torque. Horsepower is not really affected till high rpm range. I think the loss of some exhaust scavaging with the large manifold is the reason since the maf sensor shows a drop compared to the smaller manifold. All the readings are so small that they are insignificant on a street engine.
Evan
