2 members (Gdads51, 1955 1 Series), 137 guests, and 3 robots.
Topics128,089
Posts1,056,352
Members48,442
#1144885 01/16/2016 1:26 AM
I have a 66 half ton 3 speed. Got an SM465 from a 68 that I want to install. Has anyone done this ? I have the 68 bellhousing. The driveshaft is the problem. Can I have the 3 speed driveshaft modified to work ? A different yoke and lengthened ? Thanks.
Sir Searchalot
Sir Searchalot
A driveshaft shop can make anything you need. Either modify or new... or You could possibly find a donor. Never had one lengthened but have had them shortened. I'm guessing they would advise at least a new tube instead of adding a section.
I was wondering if it would be easy for a driveline shop. I will go that route. Thanks.
Crusing in the Passing Lane
Driveshafts are not lengthened, new tubes must be installed, they are shortened all the time.
Ed
Riding in the Passing Lane
You will need the bell housing that matches the 465. It has a larger center hole.
A good drive shaft shop can match up the driveshaft.
Are you in the K.C. area?
1972 Chevy c10 Cheyenne Super
Wrenchbender I am in the KC area. I have the proper Sm465 bell housing so that is OK. The sm465 is about 4 inches shorter than the 3 speed and the yoke needs to change from a splined end to a ujoint end. Can you recommend a driveline shop ?
Yes. North Manufactory. It is a mom & pop operation. 816 333-8505
He has an interesting business. When an overtheroad truck comes through town & has driveshaft problems, the truck stops all refer him to North. He goes out day-night-weekends, pulls the drive shaft & takes it to the shop, rebuilds it & takes it back. It saves the trucker days of downtime & tow bills.
Most of the guys around here that do T-5 conversions use him to modify their drive shafts.
George
Thank you George. I will call him tomorrow. He sounds like the kind of guy that can handle about anything. If the big rig guys trust him he is gold. I saw your truck years ago George and it is very nicely done. I live 4 miles west of Lenexa.
