I have a 1956 with a 350/th350 installed with a Holley 650 carb. Currently there is a non stock pedal/throttle assembly that I am not liking the placement or look of in my truck.
1. If I want to switch back to stock pedal setup, can I just purchase the TF linkage and it will hook right up to my Holley Carb, or will it only work with the stock carb setup.
2. Will it affect my kick down cable that is already installed?
After searching the forum I am still confused as a lot of the info I found was for the AD truck. Thanks.
1956 Chevrolet 3100-'Little Snap':
--Tribute to "Snappy Cartage", a family business on Manitoulin Island, Ontario, Canada
--1/2 ton, Stepside shortbox
--350 V8: Edelbrock Intake, Holly 650 Carb, H350 Transmission,, 23" Genie Shifter
