Labor Day
Labor Day
MORE wrenching?
Wrenching this Labor Day
Plenty of places to share.
0 members (), 62 guests, and 2 robots.
Topics128,009
Posts1,055,293
Members48,419
#1144576 01/14/2016 1:20 AM
can i take the heater valve out. i don't see anyway to do it. i am leaking inside the 2 pipes chevy
jimbo 24 #1144577 01/14/2016 1:33 AM
Do you mean can you completely remove the Ranco heater valve?
Yes could just direct the inflow hose and the outflow hose to the heater body.
Do you mean remove something from the Ranco valve - yes, the rubber seal can be replaced.
If the copper heat tube is broken, that can not be easily repaired.
jimbo 24 #1144579 01/14/2016 1:54 AM
inside the copper tube, isn't there seals if so how do i get to them
jimbo 24 #1144583 01/14/2016 2:13 AM
Gas Pumper
Gas Pumper
http://devestechnet.com/Home/HeaterRestore
The Ranco info is the bottom half or so.
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
jimbo 24 #1144591 01/14/2016 2:36 AM
wow thanks dave. i don't think i can handle this one but i will try.
Deve #1144784 01/15/2016 5:22 PM
dave is there a seal or washer on the end of stem because when i look inside tube there is a ring on copper. also is the stem suppose to bend to the side and back like these pics. [URL=http://i1296.photobucket.com/albums/ag3/cuz2424/VIDEO0004_zps7mlwlrsq.mp4]stem[/url] and this one [URL=http://s1296.photobucket.com/user/cuz2424/media/IMAG0079_zpsoopgrkqn.jpg.html]stem[/url]
jimbo 24 #1144874 01/16/2016 12:53 AM
Gas Pumper
Gas Pumper
You need to purchase the rebuild kit, which is just a rubber washer with a metal ring around it. The part numbers are listed in the article. You will not be able to get that shaft out like your pics because there is no reason to remove the back of the tube. If you do it like the How-To, it will all come out perfect, but be very light handed on the tabs. They break very easily. Good luck!
Deve
The Think Tank
jimbo 24 #1144899 01/16/2016 2:53 AM
If you have the stem out like that, your end cap must be off to have gotten it out. Yes it needs to swivel as it is a metal to metal seal, no rubber. The tangs need to be bent just right to keep the shaft aligned. Easier to assemble the new seal, then resolder the cap back on. Just got mine from NAPA, easy fix.
I was also able to solder a new capillary tube onto my Ranco and refill with ether. NOT an easy fix.
NHluvstruck...
1951 3100 5-window
https://stonefacegarage.wixsite.com/mysite
51 Chevy Restoration Page
jimbo 24 #1144934 01/16/2016 6:57 AM
ok shaft is already out removed the cap with heat but the shaft with those pins just goes back in no washer on the ring inside the tube. i know i need the washer at the other end.
jimbo 24 #1145068 01/17/2016 12:22 AM
Gas Pumper
Gas Pumper
That is right. Nothing on the inside of the tube. It can all be done without removing the end cap. Those tines need to be right so that they guide the valve closed properly.
Deve
The Think Tank
jimbo 24 #1145075 01/17/2016 1:02 AM
got it thanks just waiting for seal to come in
