| | | Forums66 Topics128,042 Posts1,055,516 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 11 New Guy | | New Guy Joined: Aug 2013 Posts: 11 | I seem to recall reading that I could swap a 1953 / 54 3.55 PG differential complete with the Torque Tube into my 1941 1/2 ton rear end housing. Any truth to that? Seems too easy. Thanks, JVV | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | No. Completely different housings.
Bill Burmeister | | | | | Joined: Aug 2013 Posts: 11 New Guy | | New Guy Joined: Aug 2013 Posts: 11 | Maybe they meant the whole assembly, would that be possible? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Perhaps. I'm not 100% sure if the transmission end of the torque tubes are the same or not between Passenger and Truck. I do know that the Passenger has a shorter wheelbase, which could be an issue. Someone with more experience with the closed drivelines should see this and give you more accurate advice, as my experience with them is really limited to Passenger cars. The only Truck drivelines I've really worked with have been open.
Bill Burmeister | | | | | Joined: Aug 2013 Posts: 11 New Guy | | New Guy Joined: Aug 2013 Posts: 11 | Thanks, wish I could find the article that I read to see if I recall it correctly. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | A truck has a round mounting pattern where the torque tube mounts to the axle housing, a car is oval. Installing the whole axle housing and torque tube as an assembly may be possible, but axle width and torque tube lengths would need to be confirmed. 1940-54 passenger and truck use the same spline at the front. I think it would be less work to put the aftermarket 3.55 truck gears in your housing.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Aug 2004 Posts: 1,417 ODSS Lawman | | ODSS Lawman Joined: Aug 2004 Posts: 1,417 | I have installed an AD (year unknown but 48-54) torque tube and rear axle assembly under a 1940 one-ton. The rear axle housing was already in place when I got to the truck so I do not know what was done to make the housing work.
Do you have a short or long bed?
There are a few different lengths of torque tube, so if the one you have is the correct length, you will need to likely use two u-joints to make one that will work.
SWEET Sergeant At Arms: Old Dominion Stovebolt Society BUNS?!?!?!Where we're going, we don't need no buns.....1950 GMC 450 1951 Chevy 1/2-TonThe GreenMachineIn the Stovebolt Gallery | | | | | Joined: Aug 2013 Posts: 11 New Guy | | New Guy Joined: Aug 2013 Posts: 11 | The reason I mentioned the 54 was it's a 3:55 ratio, is your conversion also a 3:55 or is it a 4:11? I don't have the truck yet (will pick up in March) so I don't know if it's a short or long bed, but I think it's a short bed. I'm at work now so can't call and ask the owner. | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | Check 1929 - 1954 Master Parts and Accessories Catalog Group number 5.504 -Carrier Assembly (torque tube lengths) 1934 to 1954 Torque tube lengths:55 55/64"----1937-38 56 39/64"----1937-40 Passenger car 57 19/64"----1939 59 1/2"-------1941-53 Passenger car 58 1/2"-------1941-46 62 1/2"-------1947 60 1/8"-------1948-54 N/A------------1954 Passenger car (check next Post) 53 7/8"-------1954 w/Hydra-Matic trans. | | | | | Joined: Mar 2011 Posts: 1,146 Shop Shark | | Shop Shark Joined: Mar 2011 Posts: 1,146 | 1941 to 1953 they used same length torque tube with the power-glide and manual shift transmissions. 59 1/2" inches Ring & pinion for PG 3.55 (I do not know the 1st year PG was used) Ring & pinion for manual (passenger car) 1951,52 - 4.11 1953 Model 1508 4.11, all others 3.70 1954 3.70 1929 to 1957 Master parts catalog does not show length of torque tube for 1954 passenger car. But shows length of the propeller shaft. Here Which says, 1941 to 1954 Passenger car all used the same length propeller shaft... 63" inches That tells me the 1954 Passenger car torque tube is the same length as 1941 to 1953 torque tube. 59 1/2" inches Your 1941 1/2 ton torque tube length is 58 1/2"inchesThe 1941 to 1954 Passenger car torque tube is a inch longer than the 1941 1/2 ton torque tube. How to measure torque tube Something to take into consideration. The truck axle is made of a heavier construction than the passenger car axle. 1942 Chevrolet Shop Manual Read Under: > Rear Axle Assembly, 1/2 ton and 3/4 ton trucks> Pinion Assembly---1/2 Ton Model> Axle Shafts | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The Powerglide came out in '51. While the lengths might be the same, the '49-'54 has a different differential than the '48 and earlier Passenger.
Bill Burmeister | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | I think the Powerglide was introduced in 1950?
6 bolt wheels (front hubs & rear axles) in cars up through 1948. 5 bolt wheels (front hubs & rear axles) in cars 1949 and later.
I think the axles can be swapped between years (for torque tubes). | | | | | Joined: Aug 2013 Posts: 11 New Guy | | New Guy Joined: Aug 2013 Posts: 11 | Wow, Thanks for all of this information, when I get some time I'll review it more closely. I do appreciate your effort to put all of this together. I'll also try to find my original reference that started this conversation.
Thanks again, very helpful.
JVV | | |
