| | | Forums66 Topics128,033 Posts1,055,531 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2012 Posts: 126 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 126 | Both left and right blinkers (front and back) work great with lights off. Neither work with lights on. Took off back blinkers and cleaned all connections. Cleaned ground wire connection on both back parking lights. All lights work.
Any ideas? Headlight bucket ground? As always, your wisdom is appreciated. | | | | | Joined: Nov 2005 Posts: 6,100 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 6,100 | Hy Oregon Tarheel, it definitely sounds like a lack of ground issue, probably for the front park/turn bulbs if you have the rear working fine now. | | | | | Joined: Nov 2012 Posts: 126 'Bolter | | 'Bolter Joined: Nov 2012 Posts: 126 | Thanks shop shark. Interestingly none of the signals worked with the lights on and all with the lights off. Then I went poking under the dash to hook up my tack light and this morning they all worked with lights on and off. Crazy. I'll still clean the grounds on the front parking lights as you suggest. | | |
