0 members (),
145
Mod | | | Forums66 Topics128,078 Posts1,056,049 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2015 Posts: 60 Shop Shark | | Shop Shark Joined: Aug 2015 Posts: 60 | By this, I mean the metal that attaches to the roll up window glass. My glass is ok, but the metal is rusting away. Where can I find just the metal to replace the old. I'm not talking about the channel that goes in the door, but that which attaches to the glass 46 Chevy pickup.
Steve
'46 Chevrolet 1/2 T. Pickup, survivor - sold '31 Ford Model A pickup
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | Steve,
They show up on ebay frequently. 1941-46 are all the same. | | | | | Joined: Mar 2005 Posts: 209 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 209 | I'm not familiar with the 41-46 channel, but if its like the newer ones, two pieces spot welded together, the U shaped piece that the glass sets in can usually be replaced with a universal lower channel by brazing or welding the old lower part to the new channel. A full service glass shop should have the channel. If you can't find it,I can probably fix you up if you can give me the length needed. John | | | | | Joined: Aug 2015 Posts: 60 Shop Shark | | Shop Shark Joined: Aug 2015 Posts: 60 | Thanks. Let me check locally
Steve
