| | | Forums66 Topics128,172 Posts1,057,038 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 60 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 60 | I dont see a provision, but maybe I'm not looking in the right place? | | | | | Joined: Aug 2000 Posts: 1,438 'Bolter | | 'Bolter Joined: Aug 2000 Posts: 1,438 | Yes. It is back from the window crank.
Dennis
40 Chevy 1/2 ton
| | | | | Joined: Feb 2014 Posts: 60 Shop Shark | | Shop Shark Joined: Feb 2014 Posts: 60 | Thanks, I knew there was a hole in the center of that lock panel but no rods or levers, but, I then looked at an extra set I got with a parts door and yes, that one has the assembly attached. Will probably change the entire part rather than trying to swap out the inside openers.
Thanks- I had just seen an old Mayberry show and the guy opened the door on an old PU by sticking his hand out the window- so I thought thats how it worked! | | |
