6 members (Gdads51, dt235sd, papas52, Bruce 1954-4100, tclederman, Forty9), 127 guests, and 1 robot.
Topics128,111
Posts1,056,258
Members48,437
What is the proper method for the initial setting of the distributor? 41, 236 GMC.
Thanks,Nick.
LIne up the ball of the flywheel to the pointer on the flywheel housing so that the number one cylinder is on a compression stroke - take out #1 spark plug and see with a small screwdriver if the piston is up (is on a compression stroke).
Loosen the distributor clamp and rotate the distributor so that the rotor points to the #1 spark plug lead.
Thanks, nothing tricky about engaging the oil pump? My distributor is out right now.
The oil pump drive can be rotated with a long flat-blade screwdriver so the tang of the distributor shaft engages properly.
Gas Pumper
Gas Pumper
While it's out, check the oiling to the rocker assembly. Remove the valve cover and take that screwdriver mentioned above, and take off the handle, then chuck the screwdriver up in your electric drill. Run the drill and make sure your rocker oiling is even and you have oil seeping out of each rocker. The drill speed should also be sufficient to see your oil pressure if you have a gauge hooked up. Put the slot in the bottom back where you found it, or you will have some playing to do to get your distributor back in.
Once its back in, make sure its down all the way. It IS possible to have the rotor turning and the engine running fine and have ZERO oil pressure because you didn't put it down all the way. Check your oil pressure once its in right away. This is discussed in detail here:
http://devestechnet.com/Home/Project1959235
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
Thanks guys will check it out as soon as I can. No shop and it's raining. Hard to complain about it,but it sure makes it hard to work on the truck in the driveway.
You will find that as you start to insert the distributor the rotor will turn some as it engages the cam drive gear. Sometimes it takes a few tries.
1951 1 Ton Completed
