6 members (55shaker, 2-Ton, carbking, Buckeye998, treegrower, 1 invisible), 344 guests, and 3 robots.
Topics128,162
Posts1,057,047
Members48,463
well, when I picked up this truck it was sitting on the ground on the drums. well the passengers side, at the corner of a cab, was in a place where evidently water either puddled, or the ditch bank was erroded, and was part of the ditch.
well the frame etc. seems to be OK, but I ended up with some rot here that I'm going to have to replace. I'm going to have to put solid floor in the rear anyway so I figure I will replace the entire floor instead of just doing half of the front.
May the force be with you - SoloWookie
solowookie.com
Anonymous
Unregistered
Anonymous
Unregistered
Solo, if ya decide to only replace the rotted section let me know I have good patch panels cut outa trucks for that battery area of the floor board.
thanks for the offer, and I will keep ya posted. I need to inspect the rest of the floor really good, and if only that part is bad then I may take you up on that.
solowookie.com
