Fixing the old truck
BUSY BOLTERS
Are you one?
Where is it?? The Shop Area
5 members (Grizzly 34s, John L., mick53, Larry P., 32Fordpuchoptop), 560 guests, and 2 robots.
Topics126,776
Posts1,039,271
Members48,100
Most Online2,175
Jul 21st, 2025
Tom
Offline
I picked up a 53 4400. I've probably read every page of this section of the forums to include all the old original shop manuals and RPO code sheets.
My question is if any 1.5 tons came with the the 2 speed rearend option? Mine has a 2 speed and I think it's from a 2 ton. However, it has all the right dash linkage, vacuum controls and related bits. If it was a swap done by a farmer he did a good job.
The 2 speed was a heavy duty option on the 1.5 ton.
1952 Chevrolet 3800 pickup
---All pictures---
Tom,
I see why you state that you could not find that 2-speed option (RPO-202) for your 4400 1.5 ton truck in documentation.
1953 RPO-202 for 5000-6000 series (no mention of 4000 series).
An optional single-speed rear axle is the only rear axle option shown for
1953 41xx series and the
1953 44xx series and the
1953 45xx series
but the optional single-speed rear axle is shown for the 1953 53xx series 1.5 ton Special. .
The same 1953 specifications manual shows that 2-speed rear option as only being available for 5xxx-6xxx series 1.5 & 2 ton trucks.
Maybe you do have a factory installed 2-speed, but (as your suggest) that one GM booklet seems to indicate your 2-speed might be a good after-market conversion?
Maybe someone has access to a 1953 Salesman Truck Data Book (mine is in NC - Brad?).
I'll dig into my literature when I get home.
My initial answer was based on my memory that some 1.5 tons could have had the 2 speed, I did not remember or know there were variations in that option or availability over the AD years.
Sorry for the incomplete info.
Grigg
---All pictures---
Are you sure it's a 4400, & not a 6400. I bought one with the wrong hood emblems on it once. Do the front bearing dust caps have bolts holding them on ?
Spanky Hardy
More pictures on Photobucket
1950 GMC 250 1-Ton
Tom
Offline
Thanks for the replies, I believe it to be factory or at least a later installed at the dealer option. It's just too clean. The front hub dust caps are threaded on not bolted like the 6400's.
The truck has the original 216 with an old brass rebuild tag. 60 bore, 20 mains and 40 on the rods. No idea if its had insert bearings installed!
I'm attempting to link my photobucket pics but the link won't paste.
Serial number P53Kxxxx indicates;
P = Series 4400 (1-1/2 ton w/ 161" wb)
53 = year
K = Kansas City Assembly Plant
xxxx = Unit Number (starting at 1001)
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1956 8400 Wrecker w/Holmes 525
1956 9200 Tractor w/Allison Automatic
1952 Willys M38 Army Jeep
1953 Willys M38A1 Fire Jeep
1978 Jeep CJ-5 Navy Jeep
1984 Jeep CJ7
Hughesville, MD
Tom
Offline
Well I finally got my photobucket link posted in my signature. The dump bed is a perfection brand aftermarket add on. I do not much care for the added weight and clutter so I'm going to sell the PTO and all related dump bits to return to a cab chassis configuration.
I tore all the old wiring out today. Cracked, spliced frayed cotton loom wiring mixed with household grade wire. It's interesting the things farmers do. He also wired the heat riser plate open long ago.
If anyone will need a home for dump parts just let me know. I could sure use a few bucks to finish getting her road worthy. Gonna be a daily driver since I work onlyna few miles away.
What type of bed will it have on it ?
Spanky Hardy
1950 GMC 250 1-Ton
Tom
Offline
Does anyone know what this sticker says? It's above the starter, found it under a layer of crud. Theres also a brass rebuild tag on the engine with rod and main specs, no block number behind distributor pad so I think it's a replacement factory engine.
http://s393.photobucket.com/user/th...60106_143133262_HDR_zps9acwwzse.jpg.html
looks like a rebuild sticker
the code behind the distributor was often ground off by a rebuilder
here are locations of various engine codes - post them for ID help
Tom
Offline
Doing a rebuild on the crapchester b carb. There's a long brass stem that is part of the power valve, is the top of the stem supposed to be notched like this?
http://i393.photobucket.com/albums/...d/IMG_20160109_231229181_zpsnr8n8a0i.jpg
(Release build 20240826)
Responsive Width:
PHP: 8.3.11 Page Time: 0.071s Queries: 14 (0.044s) Memory: 0.6512 MB (Peak: 0.7427 MB) Data Comp: Zlib Server Time: 2025-09-22 14:39:15 UTC
Valid HTML 5 and Valid CSS
