| | | Forums66 Topics128,122 Posts1,056,332 Members48,439 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2016 Posts: 6 New Guy | | New Guy Joined: Jan 2016 Posts: 6 | My 48 Loadmaster has a newer 235 (1960) and it runs great, will cruse at 45-50 mph no problem, it has a 2 speed rear, 6.13 high-8.10 low, would like to get another 10 or maybe 15 mph out of it by changing transmissions if possible. Would prefer a bolt in operation. Also want to consider an automatic trans, that would handle a 12000-14000 lb. load. My plan is to take the grain box off,and build a tiny house on it. Help ! and Thanks. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | You could look for a NP-4500 or a ZF 5 speed, that would handle the load. Any OD trans would work to increase speed.
Ed
| | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | Your brakes will not stop your truck carrying a 14k load doing 60 mph. I hope upgrading the brake system is in your plan as well. Making them go fast is easy, it's getting them to stop thats the problem... Be safe, Mike B  | | | | | Joined: Jan 2016 Posts: 6 New Guy | | New Guy Joined: Jan 2016 Posts: 6 | yes brakes will be upgraded ! | | | | | Joined: Mar 2004 Posts: 6,214 'Bolter | | 'Bolter Joined: Mar 2004 Posts: 6,214 | If your plans include newer style brakes it might be cheaper to find a modern rear with better hwy gears and brakes all as one package...just a thought. Mike B  | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | Or you could keep the drive line as original and add an overdrive box. An easy fix if you could find one.
A lot more work could get you a 700R4 like I put into the 48 2 ton. | | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | 12-14k load is maxed out or overloaded. The truck is rated for 16 and weighs 4K or a little more. The 235 is a good engine but not overly powerful. Therefore not much need for faster gears, you'll never use them... Unless being foolish on a downhill. I estimate the slow gears you have will be necessary.
Be sure brakes are in excellent shape, may consider a dual circuit master cylinder but otherwise original should be just fine. Try to keep total weight under 16k | | | | | Joined: Jan 2016 Posts: 6 New Guy | | New Guy Joined: Jan 2016 Posts: 6 | If I keep the total weight at 14K will a 700R4 hold up ? | | | | | Joined: Dec 2015 Posts: 7 New Guy | | New Guy Joined: Dec 2015 Posts: 7 | The 700r4 will handle that kind of weight just fine. Use a large cooler, stay out of OD except for long flat roads and I would recommend a beefier 3-4 clutch pack kit. It sounds heavy but realize the rearend is geared twice as low as most 3/4 tons. So that takes a lot of stress of the power train.
I slammed a 6.2 Diesel and 700r4 Into a 54 GMC M211 Deuce. It had banjo 6.17 axles too. Do use a later 700r4, fewer issues. I believe mine was from a 1991 s10. | | | | | Joined: Nov 2010 Posts: 1,159 Shop Shark | | Shop Shark Joined: Nov 2010 Posts: 1,159 | Tom,Sorry,but all I saw was a Chevy 4400. Nice truck,B.T.W...But now you have my mouth watering! Please link pics to your M211!! | | |
