5 members (Hotrod Lincoln, Southerntruck, Ponchogl, cmayna, 1955 1 Series), 186 guests, and 1 robot.
Topics128,114
Posts1,056,287
Members48,439
#1143606 01/08/2016 12:01 AM
My 48 Loadmaster has a newer 235 (1960) and it runs great, will cruse at 45-50 mph no problem, it has a 2 speed rear, 6.13 high-8.10 low, would like to get another 10 or maybe 15 mph out of it by changing transmissions if possible. Would prefer a bolt in operation. Also want to consider an automatic trans, that would handle a 12000-14000 lb. load. My plan is to take the grain box off,and build a tiny house on it. Help ! and Thanks.
Crusing in the Passing Lane
You could look for a NP-4500 or a ZF 5 speed, that would handle the load. Any OD trans would work to increase speed.
Ed
Your brakes will not stop your truck carrying a 14k load doing 60 mph. I hope upgrading the brake system is in your plan as well.
Making them go fast is easy, it's getting them to stop thats the problem...
Be safe,
Mike B smile
Mike Boteler
1956 Chevy 3100 Resto Rod
1952 Willys M38 Army Jeep
1983 Jeep CJ7 Laredo
1984 Jeep CJ7
Silver Spring, MD
yes brakes will be upgraded !
If your plans include newer style brakes it might be cheaper to find a modern rear with better hwy gears and brakes all as one package...just a thought.
Mike B smile
Mike Boteler
1984 Jeep CJ7
Silver Spring, MD
Or you could keep the drive line as original and add an overdrive box. An easy fix if you could find one.
A lot more work could get you a 700R4 like I put into the 48 2 ton.
12-14k load is maxed out or overloaded. The truck is rated for 16 and weighs 4K or a little more. The 235 is a good engine but not overly powerful.
Therefore not much need for faster gears, you'll never use them... Unless being foolish on a downhill.
I estimate the slow gears you have will be necessary.
Be sure brakes are in excellent shape, may consider a dual circuit master cylinder but otherwise original should be just fine. Try to keep total weight under 16k
•1952 Chevrolet 3800 pickup
---All pictures---
If I keep the total weight at 14K will a 700R4 hold up ?
Tom Offline
The 700r4 will handle that kind of weight just fine. Use a large cooler, stay out of OD except for long flat roads and I would recommend a beefier 3-4 clutch pack kit. It sounds heavy but realize the rearend is geared twice as low as most 3/4 tons. So that takes a lot of stress of the power train.
I slammed a 6.2 Diesel and 700r4 Into a 54 GMC M211 Deuce. It had banjo 6.17 axles too. Do use a later 700r4, fewer issues. I believe mine was from a 1991 s10.
Took #1144689 01/14/2016 10:44 PM
Tom,Sorry,but all I saw was a Chevy 4400. Nice truck,B.T.W...But now you have my mouth watering! Please link pics to your M211!!
Mo' Tater
