Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
4 members (DoubleB, greenie-reddy, Donf, mick53), 159 guests, and 2 robots.
Topics128,277
Posts1,058,441
Members48,490
#1143255 01/06/2016 12:46 AM
Hi, hope the New Years treats you right! When I bought my 57-3100 the seller said the heat did not work. I'm not sure what he meant because it does work well,the fan is strong and the air is hot, one problem is that when it first comes on it fills the cab with white smoke for a minute or two then seems to clear up. It doesn't appear to be leaking inside the cab or along the firewall, so I thought it was the heating coil blowing off sediment or maybe there was antifreeze on the outside of unit and the fan picks it up. one final piece of information, when I bought the truck the seller has connected the heating hoses to themselves by passing the heater entirely. Could I use a radiator cleaning product to remove old scale if that is what it is? Any thoughts?
Thanks, keep truckin!
Sir Searchalot
Sir Searchalot
White smoke is one thing, steam is another, particles floating another, dust another, rats nest cotton another, garbage and plant matter from the "air intake areas" is another. Be sure which it is. The only thing that can come out (if no leaks) is something on the "outside" of unit as you have said. Best idea is take it out, run the fan for a baseline look then take apart, inspect, clean, assemble and run the fan on the bench again. The sheet metal plenums could have rust, corrosion, dirt, scale, nest, debris that gets re-stirred up on each start up. That's if it's not actual smoke from the switch, fan motor or wiring. When you say coils it makes me think of electric heater, this has a heater core right? Anyway it all comes out very easily. Take the glove box off first. When someone connects the hoses together in the engine bay it means the unit was leaking into the cab. So be sure that it's not dripping, misting or seeping and is undetected by you.
